1997 Saturn SC2 wont start right away
72,000 MILES • 4 CYL • FWD • AUTOMATIC
FRANK KANE
when i turn the engine over it takes several times to start up, when it does finally start I have to feather the gas to get it running smoothly. Plus it does not idle correctly until i put it into gear. and the belt squeaks until
it starts running smooth. It starts up pretty easily if its been sitting for awhile,and takes at least 5 or more times
if I have just drove it with in the last couple of hours. If I am in heavy traffic and it is hot outside it has bordered on overheating. Im not burning through oil, power steering fluid(where I think the squealing is from). I do
have to add more coolent every couple of weeks. Any input would be much appreciated.
Oct 16, 2010 at 6:44 PM
  • 75,988 POSTS
Check the fuel pressure with a fuel pressure tester to rule out the fuel filter and fuel pump if okay-clean out the idle air control valve,test the coolant temperature sensor and throttle position sensor
Oct 16, 2010 at 7:44 PM
