1996 Saturn SC2 shifter cable
127,000 MILES • 4 CYL • FWD • MANUAL
SPENCEINTENSE
About two weeks ago i was driving and i went to put it in third and now the only gear it goes into is 3rd and it moves freely back and forth but is stuck in 3rd. so the wires on the shifter cable are being held together by some zip ties and duck tape. what should i do
Oct 28, 2010 at 10:13 AM
SATURNTECH9
  • 30,869 POSTS
So did the outer cable come off the base of the inside shifter?
Oct 28, 2010 at 10:16 AM
SPENCEINTENSE
well the first time yes and all the wires ended up getting stripped back but put zip ties around it and put it back into its sheath
Nov 1, 2010 at 3:08 AM
SATURNTECH9
  • 30,869 POSTS
Well if all your having problem with is the end that attaches to the shifter then they make a repair kit to repair that end.
Nov 1, 2010 at 4:33 AM
SPENCEINTENSE
and where could i find one of those
Nov 2, 2010 at 3:21 AM
SATURNTECH9
  • 30,869 POSTS
They have them at rockauto.com for 16.41 plus shipping.Here's a 5 percent discount code just put it in the how did you hear about us box when you order.
40936453242193
Nov 2, 2010 at 5:17 AM
