1999 Saturn SC2 Removal of shifter cables
154,000 MILES • 4 CYL • FWD • MANUAL
CHEXX87
I am just trying to get the correct procedure for removing the shift cables from the transmission housing. Thanks
Aug 26, 2010 at 8:31 AM
SATURNTECH9
  • 30,869 POSTS
What is wrong with your cable's?You might be able to fix them they sell repair kit's a lot cheaper and easier then replacing the cable's.Did the outer cable end come off the inside shifter?
Aug 26, 2010 at 11:06 AM
