Sounds likk an alarm system. With a known good battery, lock and unlock door with key, that should disable any factory alarm. If it still wont turn over, could be a bad starter/solenoid. Check for 12 volts at the small wire on the starter with key in crank position. If it has power then the starter needs to be replaced. If none, then get back to me and we will figure out where it stops
SPONSORED LINKS
Wednesday, February 11th, 2009 AT 7:41 AM
