1998 Saturn SC1 Fuel filter
1998 SATURN SC1
124,000 MILES • 4 CYL • 4WD • AUTOMATIC
LOGIZESTHE
I could not find a category that really fit my situation. When accelerating to get onto the highway the other day the car all the sudden stopped accelerating. The car did not stall out. I was able to turn it off and turn it back on. When I described this to someone else they thought the fuel filter might need to be replaced. I don't recall ever replacing it since I have owned the car. Do you think this might be the issue?
Nov 11, 2008 at 11:57 PM
DAVE H
  • 13,384 POSTS
could be the answer .. worth a try first before starting any other searches .. is your MIL on ?? if not try this first .. the filter is an in-line filter somewhere on the fuel pipes from tank usually under the car ?
Nov 12, 2008 at 7:30 AM
LOGIZESTHE
[quote:ab1a0e8975="Dave H"]could be the answer .. worth a try first before starting any other searches .. is your MIL on ?? if not try this first .. the filter is an in-line filter somewhere on the fuel pipes from tank usually under the car ?[/quote:ab1a0e8975]
What is MIL?
Nov 12, 2008 at 7:42 AM
DAVE H
  • 13,384 POSTS
MIL = malfunction indicator light .. on the dash display .. will have a light on, that is not normally on ??
Nov 12, 2008 at 8:12 AM
