1995 Saturn SC1 gas smell from inside car/failed smog
1995 SATURN SC1
ERINWRHEL
Smells problem
1995 Saturn SC1 4 cyl Manual 143433 miles
When i start my car, gas fumes are strong in the car, especially when i push the gas petal, i took it to get smogged, and it passed everything, except the evap. test. what could cause the car to give off gas fumes in the car. i smell it lightly in the engine, but strong inside. thank you
Jun 18, 2010 at 9:23 AM
SATURNTECH9
  • 30,869 POSTS
[quote:6f0b63969d="erinwrhel"]Smells problem
When i start my car, gas fumes are strong in the car, especially when i push the gas petal, i took it to get smogged, and it passed everything, except the evap. test. what could cause the car to give off gas fumes in the car. i smell it lightly in the engine, but strong inside. thank you[/quote:6f0b63969d]
Do you have any code's if so which code number's are they.You say it failed the evap test so your fuel tank wouldn't hold pressure?If you have gas fume's then you have a leak some where.I would look for raw fuel first then look at all your vapor line's for leak's.
Jun 18, 2010 at 11:01 AM
