Saturn SL2 Hesitation When Accelerating
SATURN
BLOODRAINE360
I have a saturn sl2 1.9L twin cam with about 120,000 miles.
The car has run fine until about 5 days ago i just filled the tank and about 4 miles into driving my car started to hesitate accelerating from stops and it would hesitate every now and then while cruising. I ran the tank dry and put fuel cleaner in it, I have just changed the fuel filter put new gas in it (premium) and i changed the spark plugs and for some reason it still is doing it what might it be?
Oct 22, 2007 at 8:15 AM
2CARPRO JACK
  • 11,533 POSTS
Might be a weak fuel pump or a intermittent misfire caused by a bad coil. Check engine light on or has it been on then went off? If so, you need to have the PCM scanned for codes. What kind of plugs did you put in it?
Oct 22, 2007 at 8:19 AM
BLOODRAINE360
no i had no check engine light at all it was just hesitating and i replaced the fuel pump and i put bosch spark plugs the platinum ones in and it seemed fine for a while like 10 miles then it started to hesitate some more but it was not as bad as before.
Oct 22, 2007 at 4:37 PM
2CARPRO JACK
  • 11,533 POSTS
Worst spark plugs on the market.Remove the Bosch platinums and install A/C Delco or Autolites, there is a reason those platinums are only 1.99 each, they are terrrible and create many driveability problems
Oct 23, 2007 at 12:48 AM
Suggested Repair
Remove the Bosch platinum spark plugs and install AC Delco or Autolite plugs. A weak coil or fuel-delivery issue can also cause hesitation; scan the PCM if a check engine light appears.
Conversation Summary
A Saturn SL2 with about 120,000 miles began hesitating from stops and while cruising shortly after a fill-up. The owner used fuel cleaner, replaced the fuel filter and fuel pump, added premium fuel, and installed Bosch platinum plugs, but the hesitation returned more mildly and no check engine light appeared. The expert advised replacing the Bosch plugs with AC Delco or Autolite plugs because the platinum plugs can cause driveability problems.
