1997 Saturn SC1 Erratic Temp Gauge
SATURN
CARMEN56
1997 saturn sc1 4 cyl approx 93,000 mi - temp gauge seems to be erractic - guage will bounce from almost hot to hot - under hood I noticed water hose on right hot but hose on the left side to thermostat was cool-any help would be appreciated -suspect thermostat or waterpump- thank you
Jan 21, 2007 at 2:30 AM
LOSTINMARS
  • 222 POSTS
the coolant temp sensor cracks and/or the connector at the sensor falls apart. every saturn dealer stocks the sensor and the wire. change them both. i can't tell you the number of these i've changed over the years.
Jan 26, 2007 at 9:49 PM
Suggested Repair
Replace the coolant temperature sensor and its connector/wiring pigtail together. Saturn dealers commonly stock both parts.
Conversation Summary
The owner of a 1997 Saturn SC1 reports an erratic temperature gauge that jumps toward hot, with one hose hot and the hose near the thermostat cool, and suspects the thermostat or water pump. The expert says the coolant temperature sensor commonly cracks and the connector falls apart, and recommends replacing both the sensor and the wire.
