2002 Saturn SL1 Reverse Light Switch Fix
SATURN
TQTX37A
2002 Saturn SL1, 148K mi. The switch for the reverse lights needs replaced. Where is it located? What do I need to know to replace it?
Jan 14, 2007 at 1:13 AM
PEPPERMRJ
  • 1,158 POSTS
Standard or auto shift?
Feb 7, 2007 at 10:49 AM
TQTX37A
It is a manual transmission
Feb 7, 2007 at 12:30 PM
PEPPERMRJ
  • 1,158 POSTS
[quote:b749a63372="tqtx37a"]It is a manual transmission[/quote:b749a63372]
It is located on top of the transaxle shift housing. You might want to remove the aircleaner housing and tube for easier access.
Good luck and let us know how you make out. :)
Feb 8, 2007 at 8:40 AM
Suggested Repair
On this manual-transmission SL1, the reverse light switch is on top of the transaxle shift housing. Remove the air cleaner housing and tube for easier access, then replace the switch.
Conversation Summary
The owner of a 2002 Saturn SL1 with a manual transmission asked where the reverse light switch is and what to know before replacing it. The expert said it is on top of the transaxle shift housing and suggested removing the air cleaner housing and tube for easier access.
