1999 Saturn SC2 Timing Area Noise
SATURN
JONGRENFELL
i have a 1999 saturn sc2 1.9 dohc. there is a sound coming from the timing area. it sounds like a piece of plastic. does anyone know what it could be
Apr 7, 2007 at 10:59 AM
PEPPERMRJ
  • 1,158 POSTS
Hey Jon,
What does a piece of plastic sound like? Need to narrow it down a bit. Is it with the engine running? with the car moving? You get the idea.
Good hunting and let us know. :)
peppermrj
Apr 9, 2007 at 11:54 AM
PEPPERMRJ
  • 1,158 POSTS
Noise from the timing side of the engine can be narrowed down to either internal or external. Remove the serpentine belt and try spinning all the diferent pulleys. Look and listen for anything rough, tight or loud.
Next start the engine without the belt. Is the sound still there. Yes means something internal like a timing chain or tensioner. No means it is one of the pulleys. Could be any of the accessories such as the alternator, AC, or power steering. Also be sure to check the belt tensioner and any idler pulleys.
peppermrj
Apr 10, 2007 at 8:46 PM
Suggested Repair
Remove the serpentine belt and spin each pulley, checking for roughness, tightness, or noise. Start the engine without the belt: if the noise remains, suspect an internal timing chain or tensioner; if it stops, inspect accessory pulleys such as the alternator, A/C, power steering, belt tensioner, and idlers.
Conversation Summary
The owner of a 1999 Saturn SC2 1.9 DOHC reported a plastic-like sound from the timing area. The expert asked whether it occurs with the engine running or the car moving, then advised isolating the source by removing the serpentine belt, spinning the pulleys, and running the engine without the belt to distinguish an internal timing-chain or tensioner problem from a noisy accessory or idler pulley.
