Service Engice soon light
SATURN
ANETA
I drive a 96 Saturn SL1 with mileage of 300000. Im not sure of the engine size. The problem Im having is with the Service engine soon light which is now constantly on. I took it to the saturn dealership for a diagnostic check and they said that the ingition coils and module must be replaced which is a total of almost $900, which I dont have to spend on this car. Is this for sure what is causing the light to be on? I have to do an emission test ASAP, will it pass without?
Thank you in advance for your help
Jun 7, 2007 at 1:45 AM
E40WATER12
  • 522 POSTS
Yes if they gave you the trouble codes for the check engine light, thats what has to be replaced, Also $900 is quite high for those parts with labour, better off getting independ garage doing the work, If you are unable too.
Jun 9, 2007 at 6:43 PM
