1996 Saturn SL1 Kicks When Accelerating
SATURN
HANK
I got a 96 saturn sl1 with 200000 miles and when I give it gas it starts to kick a littile when I drive .and it's roof when I sit still.I've did a complete tune up.I had a test and they said the e r g valve code.
May 3, 2006 at 1:56 PM
PEPPERMRJ
  • 1,158 POSTS
EGR (exhaust gas recirculation) valve either needs cleaning, is not functioning, or has lost it's power (vacuum or electric) source. I would bet it is stuck open.
Start with a visual inspection. Is everything is hooked up. Next try removal and cleaning. Last is to replace it.
Good hunting and let us know. :)
May 4, 2006 at 7:59 AM
Suggested Repair
Inspect the EGR valve and its vacuum or electrical connections. Clean the valve if it is stuck, and replace it if cleaning does not restore proper operation.
Conversation Summary
A 1996 Saturn SL1 with about 200,000 miles kicks slightly under acceleration and runs rough at idle despite a complete tune-up. A scan reported an EGR valve code. The expert advised checking that the EGR valve is connected, cleaning it, and replacing it if it remains stuck open or has lost its vacuum or electrical source.
