The problem is that the cooling fans does not turn on, they relay is good, the fuse is mint. Even when I turn the AC on it does not move. I check the activation signal for the cool fan relay and the negative connection is not good because I put a jumper to the chassis and the relay worked fine. However I don't know if that signal is coming from the computer or the temperature switch. Can you help me with it? Also I don't know where that temperature switch is located and if it has something to do with the fan not working when the AC is on.
1993 Saturn SL Cooling Fans Not Working
SATURN
I have a 1993 Saturn SL, motor 1.9, 102000 miles.
Apr 12, 2007 at 3:19 AM
The computer energizes the cooling fan relay. it does this after input from the coolant temp sensor or the AC switch.
Since the fan works with a jump to ground that is what I would focus on. Run a new ground and see what happens.
The coolant temp sensor should be updated to the newer brass tip design from Saturn if it has not already been.
See https://www.2carpros.com/forum/saturn-sc-1-1995-vt4925.html?highlight=wolfman for detailed instructions.
Good uck and let us know. :)
peppermrj
peppermrj
Apr 12, 2007 at 12:57 PM
Suggested Repair
Because jumping the cooling-fan relay control to chassis ground made the relay work, install a new ground and retest. The computer energizes the relay from the coolant temperature sensor or A/C switch input. If not already done, update the coolant temperature sensor to Saturn's newer brass-tip design.
Conversation Summary
The owner of a 1993 Saturn SL with a 1.9L engine reports that the cooling fans do not run, even with the A/C on, despite a good relay and fuse. Jumping the relay's negative control connection to chassis ground made it operate. The expert says the computer controls the relay using input from the coolant temperature sensor or A/C switch, recommends running a new ground, and suggests updating the sensor to the newer brass-tip design.
