Notorioous DRL
SATURN
GB
  • 5 POSTS
Hello guys,
First time I am using that forum with the hope it to be helpful.
I have just bought Saturn SL1 2000, 102000 km, and coupke of weeks after my daytime lights started acting like crazy. Latter I figured out there is some rule in their behaviour.
When I start the car and shifh the gear lever off parking position DRL turn on as normal, but couple secons later they start blinking and eventually they go off.
What I did was first I checked the fuse - it was OK, later I checked the switch at the paking brake - also OK, Check the relay, responsible for DRL by changing it with one from another Saturn, nothing different.
Now I am at Body Control Modul. Well, ... but I dont know where it is exactly.
The other suspition is that the alarm system is doing something wrong, so it would be good if I know where that system is it that mess of wires, hoses and whatever else.
I woyuld be grateful if you guys help me to find those parts and solve that problem.
Nov 14, 2006 at 11:21 AM
MARGIERINE
I have a 2001 satern L200
the car runs but we cannot shift out of park and the power locks running lights and the dome light lights goes out when we turn the ignition on we can wiggle the fuse and get them to turn on untill we touch the ignition again and everything goes out again Please help !!
Dec 3, 2006 at 7:31 AM
  • 55,781 POSTS
Sounds like the ignition switch needs replacing.
Dec 3, 2006 at 8:43 AM
