1993 Saturn SL2 Stalls in Gear
SATURN
CARS_HATE_ME:(
1993 Saturn SL2 4cyl twin cam 122000 miles every time i start the car the rpm's rev then settle at 1000 but every time i shift into drive or reverse the car almost stalls out but when i put it back into park or neutral its fine please help me :(
Apr 10, 2007 at 9:37 AM
PEPPERMRJ
  • 1,158 POSTS
Hey,
Your Satty loves you. It is just telling you it needs a little TLC. Have you ever had the ECTS (coolant temperature sensor) replaced? The original design had a plastic tip that tends to crack and leak. They play hell with idle speeds, fuel economy, starting, and more.
Have you done any preventitve maintenece lately? What? Fuel filter, air filter, plugs, wires, PCV valve, clean the EGR valve, clean the throttle body, all of these will affect idle.
Good luck and let us know. :)
peppermrj
Apr 10, 2007 at 1:04 PM
Suggested Repair
Check or replace the engine coolant temperature sensor (ECTS), which can crack at the plastic tip and disrupt idle. Also service idle-related items: fuel filter, air filter, spark plugs and wires, PCV valve, and clean the EGR valve and throttle body.
Conversation Summary
A 1993 Saturn SL2 revs on startup, settles near 1000 rpm, then nearly stalls when shifted into drive or reverse, while park and neutral are fine. The expert suggested the coolant temperature sensor and basic idle maintenance, including filters, plugs, wires, PCV, EGR, and throttle body cleaning.
