1997 Saturn SL Head Bolt Torque
SATURN
PMEDINA02
97 sl sohc 4 cyl I am putting a new cylender head but i don't know how much torque to on the bolts that go from the head to the engine, some one told me that if they had to quess it would be 50 lbs but i should really get this right so if anyone can help me out it would make my day.
May 30, 2006 at 6:53 AM
PEPPERMRJ
  • 1,158 POSTS
You tighten the bolts in sequence first to 22 ft-lbs then again in sequence to 33 ft-lbs. Lastly using a torgue angle gauge you tighten an additional 90 degrees in sequence.
Good luck and let us know. :)
May 30, 2006 at 10:30 AM
PEPPERMRJ
  • 1,158 POSTS
You are using new head bolts? They stretch to obtain proper torque.
May 30, 2006 at 10:35 AM
Suggested Repair
Tighten the cylinder head bolts in sequence to 22 ft-lbs, then again in sequence to 33 ft-lbs, then an additional 90 degrees in sequence with a torque-angle gauge. Use new head bolts, since they stretch to achieve the proper clamp load.
Conversation Summary
The owner of a 1997 Saturn SL SOHC 4-cylinder asked for the torque specification for the bolts attaching a new cylinder head to the engine, after being told a guess of 50 lb. An expert advised tightening the bolts in sequence to 22 ft-lbs, then 33 ft-lbs, followed by an additional 90 degrees with a torque-angle gauge, and noted that new stretch head bolts should be used.
