1997 Saturn SL1 Gurgling on Acceleration
SATURN
BAY25
I have a Saturn SL -1 1997, automatic transmission, 1.9 L engine, with 139 K miles on it. Great car and runs smooth on interstate and performs well above 70 mph +. However, when I accelerate up on a slope, it produces gurgling sound from under the hood (more from the front passenger side) and goes through a temporary loss of power. Nothing serious, but nowadays I see this happening frequently. I love my car and does'nt want to part with it. Any suggestions?
Apr 30, 2007 at 2:04 PM
PEPPERMRJ
  • 1,158 POSTS
Hey bay,
With the mileage on your satty I would say it is time for some maintence work. Plugs, wires, fuel injector cleaner (I like chevron with techron) in the gas tank, clean the throtle body and EGR valve, replace the PCV valve with an oem unit, and check the serpentine belt for cracks. What has been done and when?
I would also check the vacuum lines for leaks, brittleness or gumminess.
One often overlooked maintenece item is changing the tranny fluid and filter every 30,000 miles. . Use mobil 1 synthetic fluid for peak performance.
With proper maintenence you and your satty will have many more happy miles ahead.
Good luck and let us know. :)
peppermrj
May 5, 2007 at 10:29 AM
Suggested Repair
Perform overdue maintenance: replace spark plugs and wires, add fuel-injector cleaner, clean the throttle body and EGR valve, replace the PCV valve with an OEM unit, inspect the serpentine belt and vacuum lines, and change the transmission fluid and filter using Mobil 1 synthetic fluid.
Conversation Summary
A 1997 Saturn SL1 with 139,000 miles runs well at highway speeds but gurgles from the front passenger side and briefly loses power when accelerating uphill. The expert recommended routine maintenance, including plugs, wires, injector cleaner, throttle body and EGR cleaning, a new OEM PCV valve, belt and vacuum-line inspection, and regular transmission fluid and filter changes.
