1999 Saturn SL Brake Thump and High Idle
SATURN
ACH31
Saturn SL 1999. 111,000 miles. My car has recently started thumping when I brake. It sounds like it is coming from the front driver's side. It only happens when I press the brakes moderately or softly, not when I brake faster. Also, my engine has started to rev when I start the car (~2500 rpm). It goes back down after 3-4 seconds. It also revs whenever I push the clutch to take it out of gear (it increases between 200 and 500 rpm). This also goes down after a couple seconds. It seems to be idling higher while it is in gear as well. This is most noticeable in first gear, it will pull the car at about 10 mph without my even pushing the gas. I have a third problem that is the muffler and exhaust pipe have been rattling sometimes lately (when idling and starting the car). Also, 3 or so times in the last few months I have thought I smelled gas when the car started but it went away quickly. It hasn't happened consistently and it wasn't very strong either. Should I be too concerned by this? Thanks a lot!
May 12, 2007 at 6:27 PM
2CARPRO JACK
  • 11,533 POSTS
Always be concerned when you smell fuel in a car. Look underhood for leaks and vacuum lines that are not hooked up. Be sure it is full of coolant, the sensor cant read air and if it is low the engine will idle higher.Check engine light on? Have the tires inspected and rotated, might have one that is seperating, or just might need brakes
May 13, 2007 at 2:12 AM
Suggested Repair
Inspect under the hood for fuel leaks and disconnected vacuum lines, and confirm the coolant is full because a low level can raise idle. Check whether the check engine light is on. Have the tires inspected and rotated for possible separation, and inspect the brakes.
Conversation Summary
A 1999 Saturn SL with 111,000 miles thumps from the front driver's side during moderate or light braking, but not hard braking. It also revs to about 2500 rpm at startup, rises when the clutch is pressed, and idles high enough in first gear to pull the car. The exhaust rattles at idle and startup, and a brief fuel smell has occurred a few times. The expert advised taking any fuel smell seriously, checking for leaks and unhooked vacuum lines, verifying coolant level, noting any check engine light, and inspecting or rotating the tires; separating tires or worn brakes may cause the thump.
