1994 Saturn SL2 Overheat, Odometer, Brakes Fix
SATURN
OBIJI
Hi I have a '94 Saturn SL2 odometer reads 98k miles, though it stopped working probably about 60k miles ago. What can I do to get this working again?
The rear brakes (drum) squeek while braking, I've inspected the drums they look ok, I've replaced the shoes, squeeking remains.
Engine overheats while idle (sitting at stop lights, traffic, etc) I've replaced the radiator, as it popped because of this issue, I've replaced the thermostat, I've replaced the hoses, I've flushed the resevoir tank, I've replaced the Engine Temperature Coolant Sensor (the one to the fan, not the one to the PCM). The fan does not kick on idle, though it does work while the AC is turned on, or I can flip the AC on till the fan turns on, then turn the AC off, and the fan will remain on until the engine is at an acceptable temperature (3/8th of gauge).
Any help anyone can offer would be greatly appreciated (before I put the dang car in the shop!)
so frustrating...
Feb 26, 2006 at 11:46 AM
PEPPERMRJ
  • 1,158 POSTS
The two coolant sensors on the 95 and earlier model Saturns control the dashboard temperature gauge and provide information to the PCM (computer). The one for the PCM in effect controls the startup of the cooling fan by sending a signal/voltage to the cooling fan relay. I recommend the updated ECTS with the brass tip from Saturn.
Are there any codes set? If not I would think the speedo gauge is bad. The instument panel gauges are not serviceable individually. The entire panel must be replaced. If it is the speedo gauge itself try a junkyard.
The VSS (vehicle speed sensor) provides the input to the computer that drives the speedo. Check it, it's connections, and it's wiring. It will set a code if it is bad. It can be tested for resistance (700 to 900 ohms).
Good luck and let us know. :)
Feb 26, 2006 at 12:38 PM
OBIJI
[quote:acbb0d0605="peppermrj"]The two coolant sensors on the 95 and earlier model Saturns control the dashboard temperature gauge and provide information to the PCM (computer). The one for the PCM in effect controls the startup of the cooling fan by sending a signal/voltage to the cooling fan relay. I recommend the updated ECTS with the brass tip from Saturn.
Good luck and let us know. :)[/quote:acbb0d0605]
I'll give the other sensor a go, see if that corrects my problems, and idea's on the breaks? And the speedometer works great, its the mileage/odometer/tripometer thats faulty, explain that in semi-technical mostly noobish terms :-D (perferably with locations for these parts.)
Feb 27, 2006 at 11:10 AM
PEPPERMRJ
  • 1,158 POSTS
A little research about your odometer turned this up.
"A little red gear operates both the odometer and trip odometer. This gear is apparently vulnerable to interior heat in warmer climes, and the teeth break off with depressing regularity, rendering both odometers inop. This is a well-known vulnerability in our Saturns. Its about 1/4 inch in diameter, and fairly expensive (around $29.00, depending on where you order it).
Replacing this gear is not "simple" by any means. But it can be done by somebody fairly adept with hand tools, and should fix the problem permanently."
As far as the rear brakes go I would try a spring kit (hardware repacement kit from any autoparts house) and also checking the backing plate. The brake shoes rest against the backing plate in three diffent spots apiece. Some times those spots get ridges or grooves. I would try carefully grinding them flat and applying a very thin film of high temp grease at these sliding points.
Good luck with the other temp sensor. Let us know how it goes. :)
Feb 28, 2006 at 10:13 AM
Suggested Repair
Replace the PCM coolant temperature sensor with Saturn's updated brass-tip ECTS so the cooling fan can run at idle without the A/C. Replace the small red plastic gear that drives the odometer and trip meter, a common heat-related failure when the speedometer still works. For the rear drum squeak, install a brake hardware spring kit, carefully flatten ridged shoe contact areas on the backing plate, and apply a very thin film of high-temperature grease at those points.
Conversation Summary
A 1994 Saturn SL2 owner reported overheating at idle, a stopped odometer and trip meter with a working speedometer, and squeaking rear drum brakes after new shoes. The radiator, thermostat, hoses, reservoir flush, and fan coolant sensor had already been replaced, but the fan ran at idle only when the A/C was on. The expert recommended the updated brass-tip PCM coolant sensor, replacement of the small red odometer drive gear, and rear brake hardware service plus smoothing and lightly greasing the backing-plate contact points.
