1997 Saturn SL1 P0118 Code
SATURN
CHRISMFANNON
I have a 1997 saturn SL 1 with the 1.9 sohc. It has nearly 139000 miles on it and while it smokes and burns oil, it runs great. The problem I'm having is that I'm getting a code saying my coolant temperature guage has high output (po118). I replaced the coolant temperature guage but I still get the same code. I have reset it twice but it keeps coming back after running 5 minutes or so. What else could it be?
Feb 18, 2007 at 10:05 AM
CHEVY22
  • 1,375 POSTS
what exactly did you replace and where , the code is for ect sensor , engine coolant temp sensor located in the lower coolant passage in the cylinder head , is this what you replaced ??
jim
Feb 18, 2007 at 10:17 AM
CHRISMFANNON
Yes, that's what I replaced. Today The dealer told me to replace the plug also, but I just have a feeling that isn't going to do the trick.Also, how do I vote and what is it for? I'm new to this site.
Feb 19, 2007 at 8:07 AM
CHEVY22
  • 1,375 POSTS
you vote below my name
so you replaced the ect and still have the problem?? i would replace the connector , it is cheap and i have seen them short out lmk
thanks
Feb 19, 2007 at 8:18 AM
Suggested Repair
Confirm the engine coolant temperature sensor in the lower coolant passage of the cylinder head was replaced. If P0118 returns, replace the sensor connector, which can short and cause a high-output reading.
Conversation Summary
The owner of a 1997 Saturn SL1 with a 1.9 SOHC engine has code P0118 for high coolant temperature sensor output. The code returns after about five minutes even after the ECT sensor was replaced and the code was cleared. The expert confirmed the correct sensor location and recommended replacing the inexpensive connector because those connectors can short.
