1994 Saturn SC2 Hot No-Start Click
1930 SATURN
SHERELLDORSEY
94 saturn sc2 makes cliking sound when i try to crank after i turn it off
Apr 24, 2006 at 5:10 AM
RECTIFRYER
  • 20 POSTS
sounds like a starter solenoid issue, just go to a junkyard and get a used starter(20-40$)
Apr 25, 2006 at 4:55 AM
PEPPERMRJ
  • 1,158 POSTS
Now would also be a good time to have the battery and alternator checked. Make sure the cables are clean and tight also.
Good luck and let us know. :)
Apr 25, 2006 at 9:41 AM
Suggested Repair
Have the battery and alternator tested, and clean and tighten the battery cables. A hot no-crank click can also point to a failing starter solenoid; test the starter and replace it if needed.
Conversation Summary
A 1994 Saturn SC2 clicks and will not crank after it has been hot for about 30 minutes. One reply suggested a starter solenoid problem and a used starter. The expert also recommended checking the battery and alternator and making sure the cables are clean and tight.
