1997 Saturn SC2 Drum Brake Won't Come Off
SATURN
MATT426
97SATURNSC2 1.9SOHC HOW DO you back the brake off so you can take the drum off? I could really use the advice and i'll donate when i can. need the car tomorrow. can you help?
Sep 13, 2007 at 4:23 PM
SERVICE WRITER
  • 9,123 POSTS
There should be a rubber plug in the backing plate that can be removed. An adjuster wheel can be then accessed. You may be able to get a flathead screwdriver in there to turn it, it will need to be turned the way it doesn't want to turn. It may also be frozen.
Try this first: Use a 3 pound hammer and whack the front of the drum between the studs with good hits, It may pop it loose. Then you can hit the drum edge towards you at various points. You may be able to just pull it off by hand at this point by rocking it and pulling towards you.
Sep 14, 2007 at 1:05 AM
Suggested Repair
Remove the rubber plug in the backing plate and turn the adjuster wheel with a flathead screwdriver in the direction it resists; it may be frozen. If the drum is still stuck, strike the drum face between the studs with a 3-pound hammer, then tap the outer edge toward you at several points and rock and pull the drum off by hand.
Conversation Summary
The owner of a 1997 Saturn SC2 1.9 SOHC asked how to back off the brakes so a stuck drum can be removed. The expert said to access the adjuster through the backing-plate plug and turn it against its resistance, noting it may be frozen. As a first step, the expert suggested hammering the drum face between the studs, tapping the edge toward you, then rocking and pulling the drum off.
