2000 Saturn SL Dash Lights Out After BCM
SATURN
MARBLE03
I recently had my BCM replaced on my 2000 Saturn SL. The night that they replaced my BCM I noticed that some of my dash lights and AC control lights blew out. Is it possible that the replacement of the BCM caused my lights to blow or do they have nothing to do with each other?
Feb 16, 2006 at 4:32 PM
PEPPERMRJ
  • 1,158 POSTS
Hey Marble,
Welcome to the forum. :)
I assume they replaced the performance control module. I think it is just a coincidence. You might double check that the connections did not come loose while they were in there working.
Feb 17, 2006 at 1:51 AM
Suggested Repair
Treat the blown dash and AC control lights as likely coincidental with the BCM replacement. Recheck that electrical connections were not loosened while the module was being replaced.
Conversation Summary
The owner of a 2000 Saturn SL noticed some dash lights and AC control lights had blown the night the BCM was replaced and asked whether the replacement caused it. The expert assumed the performance control module was replaced, said the timing was likely a coincidence, and recommended checking that connections did not come loose during the work.
