1998 Other Saturn Models
1998 SATURN
REGGIE54
Electrical problem
1998 Other Saturn Models 4 cyl Two Wheel Drive Manual
When I turn the ignition switch to start position the 30 amp Ign. 3 blows. What sholld I do?
Sep 21, 2010 at 10:22 AM
SATURNTECH9
  • 30,869 POSTS
I would see if the purple wire to the starter is shorting to ground somewhere before the starter.If you can't find it shorting somewhere then unhook the negative battery cable.Then unhook the purple wire to the starter tape up the end real good and then hook up the battery and see if that fuse still blow's in the start position if it doesn't then you have a bad starter.Let me know what you find.
Sep 21, 2010 at 5:19 PM
