1997 Saturn SL2 Harsh Shift
SATURN
EMG1983
  • 5 POSTS
i have a 97 sl2 and had a transmission issue since i bought it. when it shifts from 2nd to 3rd and 3rd to 4th, it feels like it kind of "struggles" to get to its gears. it primarily happens after i start it and dont let it warm up first. after i drive it for a while and the engine is at warm temperature, the transition from 2nd to 3rd smooths out, but once it gets to 2nd, the engine RPMs will drop for a split second (by 200 to 300 RPM) and then increase, and THEN go into 3rd. Do you have any clue of what that could be?
Apr 21, 2007 at 12:50 PM
PEPPERMRJ
  • 1,158 POSTS
An often neglected maintence procedure is regular transmission fluid changes. On the S series they should be about every 30,000 miles. Use mobile 1 synthetic tranny fluid for best results.
Is the ses light on? Retrieve any stored codes first.
These trannies are computer controlled. You might try disconnecting the battery for a few minutes. The computer will then need several drive cycles to learn peak performance criteria.
Good luck and let us know. :)
peppermrj
Apr 25, 2007 at 12:03 PM
EMG1983
  • 5 POSTS
[quote:36bb8d5d81="peppermrj"]An often neglected maintence procedure is regular transmission fluid changes. On the S series they should be about every 30,000 miles. Use mobile 1 synthetic tranny fluid for best results.
peppermrj[/quote:36bb8d5d81]
Well, the check engine light hasnt come on yet (thank God) but the last time i had the fluid changed was when i had the 02 tranny put in (oct. 06) im gonna get the fluid changed 2morrow. i just noticed a slow leak coming from the outside filter also. I am REALLY tryin not to hate this car, but its just the small problems that are killin me.
Apr 26, 2007 at 3:16 PM
Suggested Repair
Change the transmission fluid with Mobil 1 synthetic fluid, repair the external filter leak, retrieve any stored codes, and disconnect the battery briefly so the transmission computer can relearn shift behavior.
Conversation Summary
The owner of a 1997 Saturn SL2 reports rough 2nd-to-3rd and 3rd-to-4th shifts, especially before the engine warms up, plus a brief RPM drop before the 2nd-to-3rd shift. The expert recommends regular fluid changes with Mobil 1 synthetic fluid, checking for stored codes, and resetting the computer by disconnecting the battery. The owner notes no check-engine light, a slow leak at the external filter, and plans to change the fluid.
