1994 Saturn SL1 Timing Cover Stuck
SATURN
EFUM
I have been working on my 1994 Saurn SL1 for 3 weeks
on and off.I finally got all the bolts off the timeeing Chain cover but it wont come off.I have checked over and over again looking at the Haynes manual and all.What am I missing????
Dec 31, 2006 at 1:38 AM
SERVICE WRITER
  • 9,123 POSTS
ask the dealer (Parts dept.) for a exploded view of the the cover. Or see if they have one to look at.
Dec 31, 2006 at 9:54 AM
SKYRANGER243
  • 5 POSTS
HI. I did that job to my 92 Saturn several years ago. I had the same trouble--I was using a Haynes manual also. I ultimately found that there was one capscrew which was rather well-hidden. I found it by tracing over every inch of the perimeter of the upper and lower covers--they are interlocked so you can't remove one without the other, if I recall correctly. Anyway, I recalled my frustration when I read your post, and thought I would mention it. I don't recall needing any special tool, but that dang capscrew was well-hidden. Good luck!
Jan 2, 2007 at 4:34 AM
Suggested Repair
Trace the full perimeter of the upper and lower timing covers for a well-hidden capscrew. The covers interlock, so both must be released before either can come off. A dealer parts exploded view can confirm fastener locations; no special tool was reported as necessary.
Conversation Summary
The owner of a 1994 Saturn SL1 could not remove the timing chain cover after removing the bolts shown in a Haynes manual. A service writer suggested obtaining an exploded view from the dealer parts department. Another owner who performed the job on a 1992 Saturn found a well-hidden capscrew by tracing the cover perimeter and noted that the interlocking upper and lower covers must both be released.
