2001 Saturn L200 Timing Chain Tensioner
2001 SATURN
DAVID TRIMM
My Saturn has about 60K miles..I have heard that there can be big problems from timing chain breaking. First, should I replace this now? Second, will the new part be different from the factory part? Will it have nossel to keep it lubricated better?
thanks
DLT
Jun 15, 2007 at 9:28 AM
SERVICE WRITER
  • 9,123 POSTS
The problem with the chain emmenates from the timing belt tensioner. The oil port in the tensioner plugs up stopping lubrication. The part has been upgraded to stop this. Not positive but there may be a recall on that. The dealer should be able to tell you.
I assume that is the 2.2 ecotech motor.
Jun 16, 2007 at 1:13 AM
Suggested Repair
Have a Saturn dealer check for a recall and the upgraded timing chain tensioner. The chain problem is linked to the tensioner oil port plugging and stopping lubrication; the replacement part was redesigned to prevent that.
Conversation Summary
The owner of a 2001 Saturn L200 with about 60,000 miles asked whether the timing chain should be replaced now and whether the new part differs from the factory part, including better lubrication. The expert said the chain problem comes from the timing chain tensioner oil port plugging and cutting off lubrication, that the part has been upgraded, and that a dealer can confirm a possible recall. The expert assumed a 2.2 Ecotec engine.
