2001 Saturn LW200 AC Won't Run
SATURN
HAPPYWOMAN57
My car is a 2001 Saturn LW200 with 71500 miles. The water pump was replaced 2 weeks ago and the defroster/AC has not worked since. Was working before I took it to the dealer for repair. Went back to the dealer, telling them the compressor does not come on (fan works) and they said the freon is gone and condenser may have a leak. When I pressed them from a more detailed explanation, they said maybe the compresser is bad. What trouble shooting can I do to narrow the field? This sounds expensive and I do not have an unlimited budget. I am frustrated and mad :evil: that the mechanic will not explain what is wrong with the car. How can he say "maybe" to all these items? Either he looked at it or not. I thought they did not tighten the compressor/water pump belt or a fuse had flown. Thank you for your help. :)
Apr 25, 2007 at 8:32 AM
PEPPERMRJ
  • 1,158 POSTS
Hey Happy,
These sort of thigns are very difficult. The
ac has a low pressure switch that will not let the compressor run to prevent damage. Normally a shop will refill the system including a special dye. The dye is visble under a certain light. That is how they find leaks. If there is no refrigerant there is a leak somewhere.
Now is the difficult part. Was the leaks a coincidence or was it caused by the shop. On my 96 satty I found it helpfull to move the ac unit to replace my waterpump. I did not have any leaks afterwards. If I had a weak hose or seal moving the compressor around could have caused a leak. Is that the shops responsibility?
Unless the dealer charged the system they are only guessing as to the cause of the leak. You could go back to the dealer and speak to the service manager.
Explain your concerns. See if he will agree to pay for any possible damage caused by the prior service work. It could be as simple as a bad o-ring seal. The tuff part is if there was a major failure such as a compressor or condensor chances are the cost will be your responsibility. I would find this reasonable from my experience. The other option is to find another shop for a second opinion and/or the repairs. See the Link "Avoid Car Repair Rip Off" in the blue column to the left of this post for some good sense advice.
Good luck and let us know. :)
peppermrj
Apr 25, 2007 at 11:40 AM
Suggested Repair
Have the A/C system recharged with UV dye so a low-pressure cutoff and any leak can be confirmed. Inspect the belt, seals, and hoses disturbed during the water pump job, discuss possible shop-caused damage with the service manager, and get a second opinion before replacing the compressor or condenser.
Conversation Summary
The owner of a 2001 Saturn LW200 says the A/C and defroster compressor stopped engaging after a dealer water pump replacement, although the fan still works. The dealer guessed that the refrigerant was gone, the condenser leaked, or the compressor was bad. The expert explains that a low-pressure switch keeps the compressor off when refrigerant is low, so a dye charge is needed to locate a leak. Moving A/C parts during the water pump job could have disturbed a weak hose or seal. The owner is advised to speak with the service manager and consider a second opinion; major component failures are often the owner's responsibility.
