1999 Saturn LS Overheats and Burns Oil
1999 SATURN
MISTYCLOUD
i have a 99 saturn LS, w/ about 180k, auto it leaks coolent when it is hot so i replaced the thermostat. now the service soon light comes on and it runs hot. the reservor don't have any pressure behind it and it burns oil alot. what's wrong with my car?
Oct 31, 2007 at 5:56 AM
BLACKOP555
  • 10,386 POSTS
preform a cylinder compression test. i belive you may have a blown had causing it to burn the coolant and oil due tothe oil being diluted down.
Oct 31, 2007 at 12:46 PM
Suggested Repair
Perform a cylinder compression test to check for a blown head gasket, which may be causing coolant and oil consumption, oil dilution, and overheating.
Conversation Summary
The owner of a 1999 Saturn LS with about 180,000 miles reports a hot coolant leak, no pressure in the reservoir, high oil consumption, and overheating with a service light after replacing the thermostat. The expert recommends a cylinder compression test and suspects a blown head gasket that is burning coolant and oil and diluting the oil.
