93 Saturn SC2 will not keep running
RICHARD SULLIVAN
  • 1993 SATURN
I, have a 1993 Saturn sc2 4 cylinder with double overhead cam with 89,000 miles. The car will start at times and run good for 2 or 3 minutes then it cut's out and run real rough, after a minute or two it will die and will start but will die at once. If you let is sit for 30-45 mins. It will start and have the same problems. I have put in new plugs but that has not done any good, any idea what the problem could be?
Monday, April 16th, 2007 AT 4:52 PM
PEPPERMRJ
  • 1,158 POSTS
Hey Rich,
Check out this prior post. I think it applies to your situation as well.
https://www.2carpros.com/forum/car-losing-spark-vt34751.html
Good luck and let us know. :)
peppermrj
Monday, April 16th, 2007 AT 6:22 PM
