93 saturn brakes
1993 SATURN
DUCKBOY
I have a 93 sl2. I replaced both front calipers, pads, brake hoses, and rotors. After bleeding the brake system, I cannot get the system to pressurize. The resevoir was not run dry and I've double checked the washer/gaskets. When I pump the brake pedal the engine stutters and sometimes it will stall.
Sep 3, 2007 at 12:21 AM
MERLIN2021
  • 17,250 POSTS
What were the brake problems before you did the work? And how was the pedal then?
Sep 3, 2007 at 12:46 AM
DUCKBOY
I had just bought the car and the right sides were ground down and grinding the rotors. I'm not sure how much pedal was there.
Sep 3, 2007 at 1:07 AM
