2003 Saturn L200 Rear Brake Grinding
SATURN
FFLOATER
When i Come to a stop i hear a grinding noise from the rear brakes. The car is a 2003 Saturn L 200 with 4 cylinder engine The front discs brakes are good it has rear drum brakes. I brought it to my mechanic He said it was dust in the rear brakes giving me that noise. He cleaned it. It has worked for a day but the noise came back, can you give me any advice on what to do.
Thanks. :)
Sep 15, 2007 at 11:44 PM
SERVICE WRITER
  • 9,123 POSTS
My advice is to call your mechanic and explain that his solution didn't work.
Does it only happen when braking or is the noise also heard at low speeds?
Sep 15, 2007 at 11:47 PM
MERLIN2021
  • 17,250 POSTS
If the noise bothers you that much have the drums machined.
SERVICE WRITER
  • 9,123 POSTS
Good point, I just assumed when they had the drums off they would have ground the lip off. Different techs do different things on a Clean and adjust though.
Sep 16, 2007 at 12:06 AM
ZUE
  • 76 POSTS
The cost of new drums is probably chaeper (approx 20.00 each) than taking the car to a mechanic. Consider if you are handy replacing the old drums with new ones. Also sometime the pad materials on cheaper brake shoes can be noisy.
Sep 16, 2007 at 1:54 AM
Suggested Repair
Tell the mechanic the dust cleaning did not last. Have the rear drums machined, including any lip, or replace the drums, and consider better-quality shoes if the friction material is noisy.
Conversation Summary
The owner of a 2003 Saturn L200 hears grinding from the rear drum brakes when stopping. A mechanic cleaned brake dust, but the noise returned the next day. Experts suggest following up with the shop, machining the drums, and possibly replacing the drums or noisy shoes.
