2000 Other Saturn Models Won't Start
SMILEY784
  • 2000 SATURN
Engine Performance problem
2000 Other Saturn Models 6 cyl Automatic
My car won't start. The battery won't stay charged. Coil pack was replaced but, still won't start.
Friday, May 16th, 2008 AT 7:57 PM
Does it crank over and refuses to start or it won't crank at all. Battery will not hold charge-Alternator might no be putting out or the battery is sulfated.
If it can crank over and refuses to start-do below and see what happens
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light.
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Friday, May 16th, 2008 AT 8:17 PM
