Hey Rus,
Standard or automatic tranny?
The owners manual lists all the meaning of the lights.
If my memory serves me, the light indicates either a low coolant level or a bad/gummed up level switch.
The level switch is a simple on/off float switch in the coolant bottle. It can be cleaned by draining enough coolant to remove the tank. Clean the coolant tank with a low suds detergent like cascade. Reinstall and refill.
On an automatic tranny the light could mean a disparity between the coolant temp sensor and the tranny temp sensor. Normally it would not be blinking just on solid.
Good luck and let us know. :)
peppermrj
SPONSORED LINKS
Monday, April 16th, 2007 AT 6:06 PM
