1998 Other Saturn Models won't go into reverse
1998 SATURN
127,000 MILES • 4 CYL • FWD • AUTOMATIC
PATTYMELT
  • 5 POSTS
A few months ago my 1998 Saturn SL II reverse gear stopped working. I've read that this seems to be a common problem. Do you have a suggestion for a quick, temporary fix? I am in California and getting ready to "retire" the car through the state. This is a program where the State will purchase your car for $1,000.00 if it fails the smog test in order to remove older, less-efficient cars from the road. The state will not take the car if it doesn't back up 30 feet. I am looking into Lucas Oils Tranny Fix to see if that might work. The car just races when shifted into reverse, but other gears work fine. All I need is for the tranny to engage in reverse for 30 seconds. Got any ideas?
Jun 18, 2008 at 11:09 AM
  • 75,988 POSTS
If its electronically controlled transmission -could be a problem with an actuator/shift solenoids, transmission range sensor or the transmission control module/PCM
Jun 18, 2008 at 11:52 AM
PATTYMELT
  • 5 POSTS
this is not an answer to my question. All this information is readily available on your site as well as others. Can a technician (or anyone else) specifically answer my question?
Jun 19, 2008 at 7:42 AM
  • 55,628 POSTS
Hi, has the car been scanned for trouble codes?
Jun 19, 2008 at 8:03 AM
PATTYMELT
  • 5 POSTS
No, it has not. It has a lot of miles on it and leaks a lot of oil. Prior to the reverse going out, it was making a noise when I put it in reverse. I spoke with my mechanic after the reverse stopped working and he gave me a quote of between $1100 and $1600 to fix it. Due to the high mileage, I opted for the California retirement program so I can get $1,000 to buy something else. I just need a temporary fix to get it into reverse, if possible.
Jun 19, 2008 at 8:57 AM
  • 55,628 POSTS
Its sonds like the transmission is damaged internaly and can not be fixed cheaply, sorry :-(
Jun 19, 2008 at 10:22 AM
PATTYMELT
  • 5 POSTS
any thoughts on the use of Lucas just to make it temporarily engage?
Jun 19, 2008 at 12:22 PM
  • 55,628 POSTS
I dont think it will work but you never know. Let me know what happens
Jun 20, 2008 at 4:04 AM
