1997 Saturn very rough cold start
1997 SATURN
250,000 MILES • 4 CYL • FWD • MANUAL
DOUBLEPEDALDYLAN
this car has been though a lot. almost everything on it has been replaced, yet it runs great, until recently.
minnesota just got to its cold season, and my car will barely start. if it does manage to turn over, it is barely doing so, and sounds almost like a diesel, just barely running and then maybe will smooth out. other times, it wont even do that on its own. in that case, i have to put the accelerator to the floor and hope that it catches.
also, the engine is EFI.
Dec 3, 2007 at 3:42 AM
BLACKOP555
  • 10,386 POSTS
With the slow cranking you probably have a bad battery or one that is starting to fail. For the engine not starting unless the gas is down probably relates to the slow cranking. if not then replace the coolant temp sensor and if you have a MAF sensor clean it.
Dec 3, 2007 at 4:19 AM
