1996 Other Saturn Models please help!1
JIMGSTAFSON74
  • 1996 SATURN
  • 4 CYL
  • FWD
  • 190,000 MILES
My transmission recently started taking a few minutes to engage reverse after warming up for a few minutes, when it is cold it goes right into reverse but when it warms up it takes a couple minutes, I replaced the filter and fluid but didnt help at all, it also recently started not wanting to shift from 1 to 2 untill high rpm's. What do I need to do?
Tuesday, August 26th, 2008 AT 9:53 PM
  • 31,937 POSTS
Hi there,
you may have a problem with an internal leak causing pressure loss, or a sticky shift valve, this will be something for a transmission specialist to test and report on for you.
Mark (mhpautos)
Tuesday, August 26th, 2008 AT 10:08 PM
