1995 saturn hesitates when give gas and stalls sometimes
1995 SATURN
EDWIN.VANGUNDY
  • 14 POSTS
it stalls sometimes when i come to a stop have to hold gas down to floor to start up again also it runs great driving but when i give it gas to take off it hazatates what would i ck to stop that i thought it was water in fuel put that heat stuff in gas helped once or twice tried fuel injections cleaner no change still hesitates and stall sometimes now where the air filter is at there is a sensor on the bottom of that tube that holds the air filter that sensor connection part is cracked and i think that the sensor has a brass tip could that be causeing the problem i dont have a engine scanner help me please
Mar 30, 2006 at 5:52 AM
PEPPERMRJ
  • 1,158 POSTS
Could just need a tuneup. Plugs, wires, etc. How many miles? Is the check engine light on?
:?: Post back. :)
Mar 30, 2006 at 10:26 AM
EDWIN.VANGUNDY
  • 14 POSTS
[quote:0d18ba5de1="peppermrj"]Could just need a tuneup. Plugs, wires, etc. How many miles? Is the check engine light on?
:?: Post back. :)[/quote:0d18ba5de1]
Mar 30, 2006 at 10:51 AM
EDWIN.VANGUNDY
  • 14 POSTS
[quote:5d7d059c84="edwin.vangundy"][quote:5d7d059c84="peppermrj"]Could just need a tuneup. Plugs, wires, etc. How many miles? Is the check engine light on?
:?: Post back. :)[/quote:5d7d059c84][/quote:5d7d059c84] [quote:5d7d059c84]peppermrj i dont know how to do this or what post means so here is the answer to you answer that you gave me its a 1.9l 4 door sl sadan dohc it has 16102.00 miles on it service eng light was on but i pulled all of the fuses and relay thing and put back in and now the light for engine serv. soon is not on anylonger i have replaced the spark plug and wires and pcp valve and i cleaned the air filter its one of those cone shaped filter i replaced a gas filter but it still doing what i said will a repair shop plug in there engine scanner to my computer thing on my car and tell me what bad codes are coming up so i can narrow down my search for the prob. for a small charge im sure the might do that unless you have any suggestions for me to look for or do thank for answering me [/quote:5d7d059c84]
Mar 30, 2006 at 11:06 AM
PEPPERMRJ
  • 1,158 POSTS
You can retrieve the codes yourself with just a paperclip.
Mar 30, 2006 at 11:59 AM
JMBOULWARE
You need a coolant temperature sensor. (Yes, that does sound ridiculous but it's true).
Your car has two temp sensors; one for the gauge and one for the computer. Replace them both. The sensor for the computer is malfunctioning, telling your computer that the coolant temp is wrong. This makes the computer alter how your engine runs (and why you have to hold the accelerator down to crank it). These are about $10 a piece so it will be cheap.
Also, you should pull the throttle body and clean it thoroughly. It will likely be gunked up pretty good.
I just went through this with my 1995; I replaced the TPS, the idle air control valve and cleaned the throttle body before finally finding out about the temp switch. Good luck!
Mar 3, 2009 at 11:09 PM
