2000 Saturn LS2 Dies While Driving
SATURN
ROBYNBIRD01
I have a 2000 LS2 Saturn v6 automatic w/ 138,000 miles on it. I have had all sensors replaced, alternator replace, transmission serviced. It has also had a full tune w/in the past year. My car will crank just fine but if I drive for any length of time it will just die right where it is sitting. I let it "rest" for about 20 mins. it will crank right back up. My mechanic can not seem to find the problem. No codes are showing up on the computer check. I desperately need this car to run. Any help would be appreciated.
Apr 4, 2006 at 9:52 AM
PEPPERMRJ
  • 1,158 POSTS
Sounds typical of crankshaft position sensor. Hopefully it is stull under warranty. If so just replace it. If not have it tested. Pricey little devil ($80.00 +) on the L series. The one on my S series was under $20.00.
I am not a big fan of (Autozone's) Wells electrical parts. If thats what you have I'd pay the difference and replace it it with a different brand.
good luck and let us know. :)
Apr 4, 2006 at 11:13 AM
Suggested Repair
Test the crankshaft position sensor and replace it if it fails, preferably with a non-Wells brand. On the L-series it is a relatively expensive part, so check warranty coverage first.
Conversation Summary
A 2000 Saturn LS2 with 138,000 miles cranks normally but dies after being driven, then restarts after about 20 minutes of rest. Sensors, the alternator, transmission service, and a recent tune have not fixed it, and no codes are stored. The expert says this is typical of a failing crankshaft position sensor and recommends testing or replacing it, avoiding Wells electrical parts.
