1994 Other Saturn Models car wont start
JACQUES NOLIN
  • 1994 SATURN
  • 4 CYL
  • FWD
  • MANUAL
  • 180,000 MILES
I got in the car one morning started it as usual it ran for 10 seconds and quit now wont even crank the battery is ok it just goes clunk when I turn the key nothing else where can I plug in a code reader? Thank you
Thursday, January 17th, 2008 AT 4:06 PM
MASTERTECHTIM
  • 4,750 POSTS
A code reader wont help you here. You must have something that has seized up on you, maybe alternator or ac compressor. Try removing the drive belt and see if it starts. If it does find out what froze up on you. Feedback and votes are very appreciated.
Thursday, January 17th, 2008 AT 4:35 PM
JACQUES NOLIN
I am afraid I mislead you with my description the engine is free if I disconnect the second connector from the ignition switch it will crank but as soon as I reconnect the connector it wont crank if I could get the proper wiring diagram I could probably figure it out I have a hayne's book but the diagram is not right thank you
Thursday, January 17th, 2008 AT 9:00 PM
