1993 Saturn Service Engine Soon Light
1993 SATURN
MAESOPH
  • 6 POSTS
Dear All:
"Service Engine Soon" light coming on randomly starting today. Numerous error codes in the computer to the point that the dealer believes the computer to be bad. Five hundred big ones for a new computer. Assuming they are correct and I need a new computer, I have the following questions:
A. Can I get a "used" computer somewhere?
B. Can I install it myself???
C. If so, where is it located and how do I do it?? LOL!!!!!
Any help at all is appreciated..
Apr 8, 2006 at 3:54 AM
MAESOPH
  • 6 POSTS
Dear All:
I did some checking on my car and the computer is below the dash and is loose. Is it supposed to be tightened down?? Could I simply have a grounding problem???
Apr 8, 2006 at 10:13 AM
PEPPERMRJ
  • 1,158 POSTS
I would make sure the connections and mountings are tight. 89 Inch/pounds or 10Nm. Clear the codes by either disconnecting the negative battery terminal for a few minutes or pulling the computer's fuse. Drive for a bit and see what happens. If the light comes back, pull the codes and list them.
Computer from a u pull it junkyard around here are about $20.00 bucks. Easy to install.
Be sure to discharge any static electricity in your body by touching bare metal, before touching the computer. A computer can be ruined by a static charge that is too small to even create a spark.
Good luck and let us know. :)
Apr 8, 2006 at 11:11 AM
MAESOPH
  • 6 POSTS
THANKS!!!!!!!! Cleared codes and so far they have stayed cleared......
Apr 9, 2006 at 11:22 AM
PEPPERMRJ
  • 1,158 POSTS
Don't thank us yet. It takes a few driving cycles sometimes.
Good luck tho. Let us know if they return. :)
Apr 9, 2006 at 2:03 PM
MAESOPH
  • 6 POSTS
"Service Engine Soon" light coming on randomly starting today -again. What should I do???????
Apr 22, 2006 at 9:20 AM
PEPPERMRJ
  • 1,158 POSTS
Retrieve any stored codes and post back. :)
Apr 22, 2006 at 9:22 AM
MAESOPH
  • 6 POSTS
Every time I get to the garage, the light is off...
Apr 23, 2006 at 1:37 AM
TWINCAM SATURN92
  • 6 POSTS
Posted: GM Trouble Code Info using a paper clip!
twincam saturn92, New to the forum
(5.1) Give Reputation | Statistics
All you have to do is count the flashes
example flash puase flash flash is code 12
and it will repeat 3 times for each code and the info for the code is free it will tell what codes are stored in the computer
Dec 14, 2006 at 12:41 PM
TWINCAM SATURN92
  • 6 POSTS
i didnt mean to put " can tell you why its not firing it will work with your year "
Dec 14, 2006 at 12:43 PM
MAESOPH
  • 6 POSTS
Dear All:
My "Check Engine Light" is still coming on at random and the car is running absolutely fine. I am going to leave it alone until there is at least one other symptom...
Michael D. Aesoph
Dec 15, 2006 at 12:43 PM
TWINCAM SATURN92
  • 6 POSTS
de you have the dohc motor? becuase my 92 sl2 does the same thing when i start my car the ses light comes on randomly and then when i get up to speed it turns off at like 30 and the car runs great
Dec 16, 2006 at 3:37 AM
Suggested Repair
Tighten the computer mountings and electrical connections to about 89 inch-pounds (10 Nm), then clear the codes and drive the car. If the Service Engine Soon light returns, retrieve and list the stored codes before replacing the computer. A used computer is inexpensive and easy to install, but discharge static by touching bare metal first.
Conversation Summary
A 1993 Saturn owner reported a random Service Engine Soon light and multiple codes; the dealer suspected a failed computer. The owner found the computer loose under the dash and asked about grounding, used replacements, and DIY installation. An expert advised tightening the mounts and connections, clearing the codes, and monitoring several drive cycles, noting junkyard computers cost about $20 and must be handled without static. The light later returned intermittently while the car ran normally, and the owner was told to retrieve stored codes; another reply described reading GM flash codes with a paper clip. The owner chose to wait for another symptom.
