2001 Saturn SL1 Codes P0301 P0507
2001 SATURN
DGOLDEN
I had my car tested and it came up with 301/304/507.
I installed a new camshaft sensor, checked the plugs- all .40, installed a new coil tower, new wires and plugs last year. But still the check engine light continues to come on. It occassionally goes off but always comes back on sooner or later. What else can I do? Does adding dielectic grease to all components make a difference?
Car has 122000km.
Apr 11, 2006 at 12:19 AM
PEPPERMRJ
  • 1,158 POSTS
Cylinders 1 and 4 are both off the same coil. I would test it. Also make sure it is well grounded without any corrosion on the mounting plate, the bolts, and the coil towers. Use the grease to prevent corrosion and future problems.
What kind of plugs. Some folks have had problems with the platinum plugs. Can get a bad wire or plug even new.
Camshaft sensor? Crankshaft sensor maybe?
P0507 Idle Control System RPM Higher Than Expected .
Test the IAC valve. Clean it and it's port if it tests out OK.
Good luck and let us know. :)
Apr 11, 2006 at 2:05 PM
DGOLDEN
[quote:2c484ffff8="peppermrj"]Cylinders 1 and 4 are both off the same coil. I would test it. Also make sure it is well grounded without any corrosion on the mounting plate, the bolts, and the coil towers. Use the grease to prevent corrosion and future problems.
Good luck and let us know. :)[/quote:2c484ffff8]
It turned out to be the intake manifold gasket..was torn in two and allowing air to pass by..causing all my headaches. Thanks a bunch. Debbie
May 1, 2006 at 8:36 AM
Suggested Repair
Replace the torn intake manifold gasket that was allowing unmetered air to pass. Also check the shared coil for cylinders 1 and 4, coil grounds and corrosion, plugs and wires, and test or clean the IAC valve and its port.
Conversation Summary
A 2001 Saturn SL1 with about 122,000 km had recurring codes P0301, P0304, and P0507 despite a new camshaft sensor, coil tower, wires, and plugs. The expert suggested testing the shared coil for cylinders 1 and 4, checking grounds and corrosion, using dielectric grease, verifying the plugs and wires, and testing or cleaning the IAC valve. The owner later found a torn intake manifold gasket leaking air, which resolved the problem.
