My engine has been doing some wierd stuff lately. The gauges go up and down, the engine lights go on and off (airbags, check engine, etc) then the motor will hestitae and sometimes dies. Let it sit for a while and it will start back up. Check engine doesn't stay on all the time. Have the codes check- nothing is showing up as having any issues. Disconnected most of wire harnesses, removed & replaced fuses- no help. Will run fine for a couple days then act up right after starting it up. Sometimes I can get 30 minutes away and act up again. Confused!!!! Not sure what to check next.
Jul 15, 2010 at 9:10 PM
