2000 Saturn L200 Air conditioning sensor
127,000 MILES • 4 CYL • FWD • MANUAL
POPSIE4024
So...of course my ac went out this summer. I have had the system drain, refilled and checked for leaks, but for some reason the coolant is not circulating through the system. Because it is not circulating my compressor is not kicking on. Because my compressor is not kicking on, I am not getting cold air. I was told that I need a new air conditioning pressure sensor. I looked in the my haynes manual and it tells me how to replace it and told me to see illustration. The problem is there is no illustration!! So now both my father and I are trying to find this sensor. I went to the dealership to see if they had the part but they acted as if they did not know what I was talking about. Of course they want me to come in and have them do everything I have already had done in order to tell me what the problem is. I understand they have a process they must go through, but the thought of paying a $150 for something I have already had done is not sitting to well with me. I am trying to check the small things first before I go that route. I have checked the fuse, tested the lines (as I mentioned earlier) and now I am trying to replace the sensor. Could this be a relay problem or a sensor problem? And where is the darn sensor or at least a picture of it?? Any help would be appreciated.
Jun 15, 2008 at 2:14 PM
LEGITIMATE007
  • 5,121 POSTS
the pressure sensor(low/and high) you will find on the a/c lines (low pressure hose for low sensor/high pressure hose for high sensor) and each sensor will have a little harnass and a couple of wires coming out of it those will be the sensors. I believe if they are removed then you lose your coolant. but you should be able to test them while still connected to the hose. I would check the harnass also
Jun 15, 2008 at 4:01 PM
