1994 Saturn L200
1994 SATURN L200
173,000 MILES • 4 CYL • 2WD • AUTOMATIC
BCONNER1909
I just got my saturn a couple days ago, and im pretty sure it has a bad coil pack. When it's in park, the idolings bad, and it shakes. When im driving i have to keep the gas pedel down, or else it dies. I was told by two people that i have internal damage in the motor, but i don't think their is. If you have any advice please let me know. I would greatly appreciate it!
Apr 22, 2008 at 5:20 PM
MOPARNUT1393
  • 34 POSTS
well a coil pack is usually good or bad but if you have more than one you may have a bad one but if not i would say you should check oil and look for water, maybe a timing belt is stretched and has slipped a cog and the timing is off but id look around and see if all the cylinders are firing before you change a coil pack
Apr 22, 2008 at 5:26 PM
