2002 Saturn L100 Starting problem
56,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHIEFSTEVE1
I have a saturn L 100 series car and it will not start about one in ten times. It cranks normaly. If I let it sit for a while it then starts and runs properly.
Any ideas would be great.
Mar 8, 2010 at 12:21 PM
  • 75,988 POSTS
Do below to determine whether it's fuel or spark issue.
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 8, 2010 at 12:24 PM
BASSTECH
  • 236 POSTS
quick question, does the security light come on or flash when it dosen't start?
Mar 9, 2010 at 8:26 AM
