2002 Saturn L100 dying after 4000rpms
136,000 MILES • 4 CYL • 2WD • AUTOMATIC
DB185033
I have replaced the coil module, ignition module, boots and plugs. It was sucking oil from the vent tube through the throttle body causing fouling plugs. I blocked that off to see if the condition would change. It continued to die off after 4000rpms but now it makes a click (like a solenoid) then acts as if it is sucking wind and the tranny won't change out. Now if you reduce the rpms it will start to run like normal, but with a minimal loss of power.
Nov 25, 2008 at 4:31 AM
PEAR69
  • 1,482 POSTS
There is probably a rev limiter built into your computer. 4000 rpms is close to/and/or is the rev limit. When you hit this limit the engine will shut down. What is the red line for your engine?
Nov 25, 2008 at 4:37 AM
