2001 Saturn L100 No power up hills
2001 SATURN L100
60,768 MILES • 4 CYL • FWD • AUTOMATIC
COOLCARS
Just wondering what you think? I had 2 codes p0300 which is misfire detection and a p0172 system too rich bank 1. Test drove vehicle while watching the misfire graph and cyl 1 and cyl 2 had several hits so i changed the plugs..After thst vehicle runs good but has no power up hills the check engine flashes but dont store any codes or sets any history codes...Any suggestions....
Apr 13, 2010 at 10:59 AM
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen sensor/s
Apr 13, 2010 at 11:25 AM
