2000 Saturn L100 Won't start sometimes
FRANNIE1
  • 2000 SATURN L100
Engine Mechanical problem
2000 Saturn L100 4 cyl Front Wheel Drive Automatic 103K miles
Yesterday my car wouldn't start after it had been parked for only 30 minutes in shopping center parking lot. After shopping, tried 3 or 4 times to start the engine; it would crank & turn over but not start. Waited about 5 minutes & tried it again. This time it started right up and was fine the rest of the day. This is the first time that has happened. Battery is new, oil & filter was changed about 30 days ago, however, car has not had a major tuneup/service in about a year or 2 (due to lack of money). What might problem be and how expensive to fix?
Thanks very much for any and all help!
Thursday, March 11th, 2010 AT 1:46 PM
Next time it happens, don't wait for nothing do below immediately to determine whether it's fuel or spark issue.
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Thursday, March 11th, 2010 AT 3:47 PM
