2005 Saturn Ion clutch seems to be slipping
30,000 MILES • 4 CYL • FWD • MANUAL
MARCZIJ
when i shift gears the rpms rev high then go back down,the clutch seems to be slipping,also the change oil light won,t go off and i changed the oil and filteras required? can you suggest any way i can correct this?
Mar 9, 2010 at 6:32 PM
SATURNTECH9
  • 30,869 POSTS
[quote:8f9b7ab6ce="marczij"]Transmission problem
2005 Saturn Ion 4 cyl Front Wheel Drive Manual 30000 miles
when i shift gears the rpms rev high then go back down,the clutch seems to be slipping,also the change oil light won,t go off and i changed the oil and filteras required? can you suggest any way i can correct this?[/quote:8f9b7ab6ce]
lets start with the easy stuff reseting ur oil light turn the key on then press ur trip reset untill u see oil reset on the display then hold the oil reset down till u hear ding ding then u know its reset.as far as ur clutch slipping if its slipping then all u can really do on that is have it checked out and if its bad then replace it.
Mar 10, 2010 at 6:50 AM
